方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>燃烧特性 |
参考标准 | 暂无 |
采用LaVision公司特色的以高速图像增强器为核心部件构成的平面激光诱导荧光(PLIF)测试系统对透明单冲程压缩机用于均质混合进气压缩燃烧(HCCI)进行了实验研究。
In this study, experimental results of homogeneous
charge compression ignition HCCI of n-butane in a
single shot machine are presented. N-butane
measurements are compared with a multizone model.
Individual zones are calculated using a perfectly stirred
reactor and Chemkin chemistry. The influence of
temperature before combustion on heat release rate and
duration of combustion is shown in a sensitivity analysis.
As a perfect homogeneous temperature and fuel
distribution are difficult to establish under experimental
conditions, deviations from perfect homogeneity are
shown. The influence of a hot surface in the cylinder
head in terms of heat release rate and ignitability is
examined. Further, dual fuel injections of n-butane and
diesel are studied to trigger the n-butane ignition with a
defined start of combustion.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
