方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 理化分析>其他 |
参考标准 | 暂无 |
采用LaVision公司特色的以DaVis软件平台和高速相机为基础构成的喷雾高速成像诊断测量系统(SprayMaster)对喷雾导引火花塞引燃直接喷射发动机(SGSIDI)内部燃料混合,注入等过程进行了测试和研究。
Fuel/air mixing, in-cylinder flow, and spark discharge exhibit
large cycle-to-cycle variations in internal combustion engines. To
fully understand how each of those parameters affects ignition
stability, it is necessary to measure them at high rate and in more
than one dimension. Imaging diagnostics, such as laser induced
fluorescence (LIF) for fuel concentration measurements and particle
image velocimetry (PIV), have been useful in engine research
and development for almost two decades now. However,
measurements were mostly restricted to one image per cycle
and often not even in consecutive cycles. Very recently, the use
of CMOS cameras, multi-stage image intensifiers, and high repetition
rate diode-pumped Nd:YAG lasers has allowed sustained
LIF imaging measurements at 12 kHz (= 1 crank angle degree at
2000 RPM) for more than 1600 consecutive engine cycles. This
approach can be combined with PIV to yield simultaneous fuel
distribution and velocity fields. Here we focus on the description
of some intricate details of the high-speed flow diagnostic development
and illustrate their use with examples obtained in a
spray-guided spark-ignition direct-injection engine.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
