方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A new method to describe small scale statistical information from passive scalar fields has been proposed by Wang and Peters (2006). They used direct numerical simulations (DNS) of homogeneous shear flow to introduce the innovative concept. This novel method determines the local minimum and maximum points of a fluctuating scalar field via gradient trajectories starting from every grid point in the direction of the steepest ascending and descending scalar gradients. Relying on gradient trajectories, a dissipation element is defined as the region of all the grid points the trajectories of which share the same pair of maximum and minimum points. The procedure has also been successfully applied to various DNS fields of homogeneous shear turbulence using the three velocity components and the kinetic energy as scalar fields. To validate statistical properties of these elements derived from DNS (Wang and Peters 2006, 2008), dissipation elements are for the first time determined based on experimental data of a fully developed turbulent channel flow. The dissipation elements are deduced from the gradients of the instantaneous fluctuation of the three velocity components u5, v5, and w5 and the instantaneous kinetic energy k5, respectively. The required 3D velocity data is obtained investigating a 17.82 × 17.82 × 2.7 mm3 (0.356 × 0.356 × 0.054 ) test volume using tomographic particle-image velocimetry (Tomo-PIV). The measurements are conducted at a Reynolds number of 1.7× 104 based on the channel half-height and the bulk velocity U. Detection and analysis of dissipation elements from the experimental velocity data are presented. The statistical results are compared to the DNS data from Wang and Peters (2006, 2008).
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
