方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司独特的充氦肥皂泡示踪颗粒做示踪粒子,在立方米尺度量级的体空间,采用5台高性能sCMOS相机做成像记录,利用最新一代的抖盒子分析技术(Shake the box)获得了空气对流场的3D3C速度矢量场结果。
We present results from two large-volume volumetric flow experiments. The first of these, investigating a thermal
plume at low velocities (up to 0.35 m/s) demonstrates the abilities and requirements to reach volume sizes up to
and probably beyond one cubic meter. It is shown that the use of Helium filled soap bubbles (HFSBs) as tracers,
combined with pulsed LED illumination yields high particle image quality over large volume depths. A very
uniform particle imaging, both in space as well as in time enables using high particle image concentrations (up to 0.1
ppp), while still being able to accurately reconstruct the flow using Shake-The-Box particle tracking.
The experiment consisted of time-resolved volumetric flow measurements of a convectional plume within a volume
of approx. 0.55 m3
(550 liters). The light yield needed for such a large scale measurement is realized by using HFSBs
with 300 ?m diameter as tracers and illuminating the measurement region using high-power, scalable arrays of
white LEDs. Applying the Shake-The-Box algorithm, up to 275,000 bubbles could be tracked simultaneously.
Interpolating the results on a regular grid (using ‘FlowFit’) reveals a multitude of flow structures. The setup can be
scaled to larger volumes of several cubic meters, basically only being limited by the number and power of available
LEDs and high-resolution cameras with sufficient frame-rate and pixel sizes.
A second experiment showcases the possibilities to reach higher flow velocities, while still measuring within a
comparatively large volume, by applying high-speed imaging and advanced LED illumination. An impinging
turbulent jet was investigated in volumes ranging from 13 to 47 liters, depending on the repetition rate of the camera
system. The results show that even at a repetition rate of 3.9 kHz and flow speeds up to 17 m/s the tested system
was able to deliver images that allowed for a reliable and accurate tracking of bubbles.
Again, the use of more LEDs would allow for larger volumes. New generations of high-speed cameras should
enable the use of even higher flow speeds – thus enabling large-volume measurements in typical low speed wind
tunnel experiments at high spatial resolution (provided enough HFSBs can be produced).
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
