方案下载应用领域 | 石油/化工 |
检测样本 | 工业气体 |
检测项目 | 理化分析 |
参考标准 | 暂无 |
采用Ekspla公司的NT342型可调谐纳秒激光器光源,采用超级分辨算法对氩和氖光谱分辨率增强进行了研究。
This paper presents the principles and application of a super-resolution (SR) technique,
based on a L1-Norm minimization procedure. In particular, the technique is applied to improve
low-resolution resolution spectra as obtained from the optogalvanic effect in Neon and Argon
discharges over the 413-423 nm wavelength range. By applying the super-resolution algorithm
to the experimental data, a surprising 70-fold reduction of the linewidth is achieved allowing to
resolve prior indistinguishable peaks. It is found that further improvements on the resolution
are limited by the signal to noise ratio of the original spectra. The importance of a suitable
mathematical representation of the experiment and the discussion on other applications of this
super-resolution technique in spectroscopy are also presented.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
