方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | 理化分析 |
参考标准 | 暂无 |
采用Ekspla公司NT342型号纳秒可调谐激光器,对氟苯并芴核心聚合物作为低阈值高增益放大激光介质的可行性进行了研究。
Deliberate control of intermolecular interactions in fluorene- and benzofluorene-cored oligomers
was attempted via introduction of different-length alkyl moieties to attain high emission amplification
and low amplified spontaneous emission (ASE) threshold at high oligomer concentrations.
Containing fluorenyl peripheral groups decorated with different-length alkyl moieties, the oligomers
were found to express weak concentration quenching of emission, yet excellent carrier drift
mobilities (close to 102 cm2/V/s) in the amorphous films. Owing to the larger radiative decay
rates (>1.0109 s1) and smaller concentration quenching, fluorene-cored oligomers exhibited
down to one order of magnitude lower ASE thresholds at higher concentrations as compared to
those of benzofluorene counterparts. The lowest threshold (300W/cm2) obtained for the fluorenecored
oligomers at the concentration of 50 wt % in polymer matrix is among the lowest reported
for solution-processed amorphous films in ambient conditions, what makes the oligomers promising
for lasing application. Great potential in emission amplification was confirmed by high maximum
net gain (77 cm1) revealed for these compounds. Although the photostability of the
oligomers was affected by photo-oxidation, it was found to be comparable to that of various organic
lasing materials including some commercial laser dyes evaluated under similar excitation
conditions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
