采用结构化平面激光照明成像技术实现可靠的LIF/MIE方法测量喷雾液滴粒径
2018/02/02   下载量: 4
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
采用Artium公司特色的DPSSL激光器作光源的相位多普勒粒子干涉仪(PDI)对用LIF/MIE比值法测量喷雾液滴粒径以及用结构化平面激光照明成像方法进行有效性分析提供了可靠的标定。
方案下载
配置单
方案详情
In this article, Structured Laser Illumination Planar Imaging
(SLIPI) is used in combination with the LIF/Mie ratio technique for
extracting a reliable two-dimensional mapping of the droplets Sauter Mean
Diameter (SMD). We show that even for the case of a fairly dilute spray,
where single scattering events are in majority, the conventional LIF/Mie
technique still remains largely affected by errors introduced by multiple
light scattering. To remove this unwanted light intensity on both the LIF
and Mie images SLIPI is used prior to apply the image ratio. For the first
time, the SLIPI LIF/Mie results are calibrated and compared with
measurement data from Phase Doppler Interferometry (PDI).
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 海洋层积云中细雨的观测和研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 采用结构化平面激光照明成像技术实现可靠的LIF/MIE方法测量喷雾液滴粒径
