方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用4千赫兹重复频率的Nd:YAG激光器的紫外355nm输出,对气体燃料燃烧火焰的外部几何形态,形貌随时间的变化及其和燃烧不稳定性的关系进行了测量,记录和分析。得到了许多重要的规律。
In the past, flame geometry was found to play an important role in determining when strong pressure
fluctuations associated with a combustion instability occur in a gas turbine model combustor. The goals of
this study were to use flame surface area as a more accurate way to quantify the flame shape and the heat
release rate, in lieu of chemiluminescence; to accurately resolve both the spatial structure and the time history
of the heat release fluctuations, and to show that kilohertz formaldehyde planar laser-induced fluorescence
provides a new way to achieve these goals. The dual-swirl burner, developed at DLR Stuttgart by
Meier et al. was operated using dimethyl ether (DME) to study fluctuations in the flame surface area, flame
brush, flame length, and heat release rate. To understand the instability, accurate measurements are needed
of the correlation between heat release rate fluctuations and pressure fluctuations. Thus heat release rate
must be recorded as a function of time and space. However conventional chemiluminescence offers only
a line-of-sight measurement. High-speed CH2O PLIF was applied to study the motion of flame surfaces
in response to the pressure oscillations. Results show that the flame surface density fluctuated at the acoustic
frequency (typically 320 Hz). The frequency of the combustion instability was found to increase as
either the gas velocity or the flame speed was increased. These trends are consistent with previous n-s theories
that model the convective time delay. Strong pressure oscillations occur for conditions when the flame
is nearly flat; the instability disappears when the flame becomes V-shaped. The explanation is that all points
on a flatter flame have the same convective time delay but this is not true for the V-flame geometry.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
