方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用双腔Gemini型PIV Nd:YAG 激光器系统做照明光源。532nm波长,200毫焦/脉冲输出能量。脉冲宽度5纳秒。测量部分采用4台LaVision Imager sCMOS高灵敏度相机。相机像素5百50万.进行水流通过突扩管的3D3C层析PIV流场测量。
The jet flow past an abrupt expansion under some conditions switches intermittently between two states: quasi-axisymmetric expansion and gyroscopic-like precessing motion. In this work an experimental analysis is carried out by means of Tomographic Particle Image Velocimetry (Tomo-PIV).The self-excited flow precession generated by a 5:1 expansion of a round jet in a coaxial cylindrical chamber is investigated. The experiments are performed at a Reynolds number equal to 150,000. Proper Orthogonal Decomposition (POD) is applied to extract information on the organization of the larger structures of the precessing motion. This technique highlights the dominance of three modes: the first two are associated to the jet precession; the third one is representative of the axial motion. Furthermore, an approach based on the modal energy for the evaluation of the precession probability is presented. The application of a stability criterion shows that the self-induced swirl flow results to be unstable within the jet shear layer. The instability is responsible for the generation of helical-shaped vortices in the near field, instead of the expected phenomenology of the ring-vortices generation of circular jets.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
