方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 无需 |
使用英国Litron公司Nano T 135-15 PIV型激光器做光源,用LaVision imager intense相机做成像器件,对1立方分米尺寸正方体内纳米流体的湍流和自然对流流动进行了测量,获得了重要的流场速度场结果。
tIncreased cooling performance is eagerly required for many cutting edge engineering and industrial tech-nologies. Nanofluids have attracted considerable interest due to their potential to enhance the thermalperformance of conventional heat transfer fluids. However, heat transfer in nanofluids is a controversialresearch theme, since there is yet no conclusive answer to explain the underlying heat transfer mech-anisms. This study investigates the physics behind the heat transfer behavior of Al2O3–H2O nanofluidsunder natural convection. A high spatial resolution flow velocimetry method – Particle Image Velocime-try – is employed in dilute nanofluids inside a Rayleigh-Benard configuration with appropriate opticalaccess. The resulting mean velocity and flow structures of pure water and nanofluids are reported andtheir overall heat transfer performances are compared for Rayleigh numbers, Ra, of the order of 109. Thispaper aims to identify the contribution of the suspended nanoparticles on the heat and mass transfermechanisms in low flow velocity applications, as those occurring during natural convection. The outcomeof this work is a first step towards the evaluation of the applicability of nanofluids in applications wheremore complex heat transfer modes, namely boiling and Critical Heat Flux, are involved that are of greatimportance for the cooling of Fusion reactors.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
