方案下载应用领域 | 石油/化工 |
检测样本 | 柴油 |
检测项目 | |
参考标准 | 暂无 |
用美国Artium公司的新一代的PDI-200MD型粒子粒径速度测试系统,测量了柴油喷雾对象的喷雾液滴粒径和速度,并以此来检验验证一种新型的测试方法L2F技术的有效性。
A laser 2-focus velocimeter (L2F) has been applied for measurements of velocity and size of droplets in diesel sprays. The maximum data acquisition rate of 15 MHz has been achieved by using FPGA in order to capture every droplet which appears in the micro-scale measurement volume. A method of evaluating the mass flow rate of droplets was proposed, and the distance between droplets was adopted as an indicator of the number density of droplets and the heterogeneous structure of sprays. The diesel fuel spray was injected
intermittently into the atmosphere by using a 5-hole injector nozzle. The orifice diameter of the injector nozzle was 0.113 mm, and the injection pressure was set at 40MPa by using a common rail system. Measurements were conducted in the spray on 10 planes from 5 to 25
mm downstream from the nozzle exit. It was shown that the velocity of droplet was the highest at the spray center and decreased towards the spray periphery. The size of droplet at the spray center decreased downstream and that at spray periphery increased downstream. The mass flow rate near the spray center was larger than that in the spray periphery region. It was confirmed that the fuel mass per injection evaluated by the proposed method based on the L2F measurement was nearly equal to the injected mass in a plane further than 15 mm
from the nozzle exit. The probability density of droplet with a distance shorter than 5 m to the adjacent droplet increased remarkably near the spray center 5 and 12 mm downstream from the nozzle exit. It is thought that a region of high number density of droplet exists at the spray center near the spray tip when the spray penetration is shorter than 15 mm.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
