方案下载应用领域 | 钢铁/金属 |
检测样本 | 其他 |
检测项目 | 理化分析>粒度 |
参考标准 | 暂无 |
采用LaVision公司的阴影法粒子粒径和速度测量分析系统,对液滴脉冲管液态D2工具钢液滴,在下落,冷却,固化过程中的液滴粒径和温度参数进行了测量,并和其它类型测试设备进行了对比分析。
D2 tool steel powders were produced using a drop tube-impulse atomization technique. In order to measure the radiant energy and droplet size of atomized D2 steel droplets, DPV-2000 (Tecnar Automation Ltée, St. Hubert Quebec, Canada) was utilized. In-situ velocity and droplet size of the atomized droplets were also measured using shadowgraphy technique (Sizing Master Shadow from LaVision GmbH in Gottingen, Germany). A 3D translation stage was designed, constructed and installed inside the drop tube system. DPV-2000 and shadowgraph were then mounted on the translation stage. Using this stage, online measurements were conducted at 4 cm, 18 cm and 28 cm distances below the crucible. Using liquid (fully undercooled) and semi-solid behavior of droplets, it was possible to estimate the droplet size and temperature at which solidification starts. These values were then confirmed by the thermal model using experimentally estimated primary phase undercooling values. It was concluded that DPV-2000 is not accurate enough to detect the amount of recalescence during solidification of the droplets as they fall. But, comparing to the results from the heat loss model, reasonable estimates were obtained for different particle sizes solidifying at different distances using online measurement tools.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
