方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的平面激光诱导荧光(PLIF)测试系统,同时测量湍流火焰中的OH和CH2O自由基。测试系统由两台Nd:YAG激光器(Continuum Surelite), 两台染料激光器(Sirah Cobra-Stretch) 和两台高分辨率双脉冲增强型CCD相机构成(Lavision Nanostar). 系统还可以测量OH自由基的自发荧光图像。
In this work, we report on the direct measurement of heat release rates via simultaneous laser-induced fluorescence of OH and CH2O radicals using planar laserinduced fluorescence (PLIF). The product of the two images is shown to correlate with the forward production rate of the HCO radical, which in turn has been found to correlate well with heat release rates in premixed hydrocarbon flames. Heat release rate measurements were also taken with OH* for comparisons with the results from the laser-based technique. The measurements were made in a lean turbulent premixed flame subject to acoustic forcing; this flame mimics the instabilities encountered in lean premixed pre-vaporized combustors (LPP). As the scheme is based on probing radical species that participate in the major heat release reactions, it is the closest nonintrusive measure of heat release rate currently available and thus presents a very
useful diagnostic tool in combustion research.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
