方案下载应用领域 | 医疗/卫生 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
用400毫焦的PIV激光器作光源,用LaVision的ImagerHS型高速相机做成像器件,用LaVision的DaVis软件平台分析处理图像采集数据。对生物瓣膜假体的流体动力学性能进行了测试,分析。
The aim of the present in vitro study was the evaluation of the fluid dynamical performance of the Carpentier-Edwards PERIMOUNT Magna Ease depending on the prosthetic size (21, 23, and 25 mm) and the cardiac output (3.6–6.4 L/min). A selfconstructed flow channel in combination with particle image velocimetry (PIV) enabled precise results with high reproducibility, focus on maximal and local peek velocities, strain, and velocity gradients. These flow parameters allow insights into the generation of forces that act on blood cells and the aorticwall.Theresults showed that the 21 and 23mmvalves have a quite similar performance. Maximal velocities were 3.03±0.1 and 2.87±0.13 m/s; maximal strain ???, 913.81±173.25 and 896.15±88.16 1/s; maximal velocity gradient ???, 1203.14 ± 221.84 1/s and 1200.81 ± 61.83 1/s. The 25mm size revealed significantly lower values: maximal velocity, 2.47 ± 0.15 m/s; maximal strain ???, 592.98 ± 155.80 1/s; maximal velocity gradient ???, 823.71 ± 38.64 1/s. In summary, the 25mm Magna Ease was able to create a wider, more homogenous flow with lower peak velocities especially for higher flow rates. Despite
the wider flow, the velocity values close to the aortic walls did not exceed the level of the smaller valves.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
