方案下载应用领域 | 航空航天 |
检测样本 | 航空 |
检测项目 | |
参考标准 | 暂无 |
采用两台Phantom 9.1v 型高速相机和双帧双脉冲YAG激光器,以及LaVision的DaVis8.3.0软件构成2D3C粒子成像测速系统。对风洞中的震动翼尖襟翼的空气动力学特性进行了测量研究。
In the present study, an oscillating membrane flapper was pivotally attached to the tip
of a conventional rigid wing. Stroke-averaged aerodynamic forces were measured for the range of the flapping frequency, showing significant increases in the lift coefficient and lift-to-drag ratio for the wing with a flapper. Major vortex patterns were deduced from observations of smoke-wire visualization and 2D phase-locked particle image velocimetry (PIV). The centerline of the primary vortex wanders in the counterclockwise direction. On the contrary, its core rotates in the same sense of rotation as a wingtip vortex in a conventional wing. The secondary weaker vortex of opposite rotation lasts for a half stroke. The vortex ring sheds from the flapper during the second half of the upstroke and pronation. The outer parts of the vortex system are much stronger than the inner ones. The circulation and size of vortices decrease significantly at the most distant station from the wing. Strong vertical jets were found in smoke-wire visualization and confirmed with velocity and vorticity fields obtained by PIV. These jets are formed between undulating vortices and inside of the vortex ring. The jet airflow moves away from the flapper and downward or upward depending on the flapping direction.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
