方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
针对喷雾对象,基于结构化平面激光照明成像SLIPI技术,采用LaVision公司的SprayMaster测量系统,对喷雾对象的粒径,浓度和温度分布进行了测量。同时采用美国Artium公司的PDI-TK2 相位多普勒粒子干涉仪,对粒径测量结果进行了标定。
Structured laser illumination planar imaging (SLIPI) is a technique capable of
suppressing multiple light scattering effects in optically dense sprays, resulting in
spray images without blurs and with enhanced contrast. The novelty of the work
presented in this thesis concerns the applications of a variety of SLIPI-based
techniques for the measurement of droplet size, droplet concentration, and liquid
temperature in atomizing sprays. Two types of spray systems are investigated
here: 1) Steady hollow-cone water sprays using temporally averaged imaging.
2) Transient Direct-Injection spark ignition (DISI) biofuel sprays using
instantaneous imaging.
The temporally averaged measurements are performed using three-phase SLIPI
(3p-SLIPI) with liquid injection pressures in the range of 20–50 bar and at ambient
conditions. Droplet sizing is obtained by combining SLIPI with the laser-induced
fluorescence (LIF)/Mie ratio approach, where the droplet Sauter mean diameter is
deduced after calibration with phase Doppler anemometry measurements. The
droplet concentration and liquid volume fraction are obtained by combining the
SLIPI-LIF/Mie method with light transmission measurements. This is performed
using a laser sheet scanning approach, which provides three-dimensional
quantitative reconstructions. Finally, the spray temperature is obtained by
combining SLIPI with two-color LIF ratio thermometry for a liquid temperature
ranging from 25–55°C. It is found that multiple light scattering induces
measurement errors even for sprays having singly scattered photons in majority.
This finding, therefore, strongly supports the application of SLIPI for quantitative
spray measurements, even for optically dilute sprays. The 3p-SLIPI approach is
based on recording a minimum of three modulated sub-images successively, each
having a different spatial phase; therefore, it has been primarily used for
To circumvent this limitation, two novel instantaneous imaging approaches, 2p-
SLIPI and 1p-SLIPI (corresponding to two-phase and one-phase, respectively),
have been developed. In the 2p-SLIPI optical setup, the “lines structure” is
optically shifted by exploiting the birefringence property of a calcite crystal. This
novel optical approach is used to image spray dynamics in ethanol and butanol
DISI sprays at liquid fuel injection pressures of 80 and 160 bar, where the spray
chamber is operated at 2-bar air pressure. Finally, the results from instantaneous
2p-SLIPI and 1p-SLIPI imaging have been compared, showing promising
applications for the study of spray dynamics.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
