方案下载应用领域 | 电子/电气 |
检测样本 | 电子元器件产品 |
检测项目 | |
参考标准 | 暂无 |
采用立陶宛Ekspla公司的PL2210型脉冲皮秒激光器做光源。通过SPELS公司的单粒子事件模拟测试系统。对商用铁电存储器(FRAM)单粒子事件效应及应用中子诱导位移破坏的缓解技术进行了实验研究。
The single event effects (SEE) in commercial Ferroelectric Random Access Memory (FRAM) were investigated using heavy-ion and pulsed laser. Stable data upsets affecting one to several rows and transient data upsets affecting hundreds to even thousands of rows were both observed, and the corresponding sensitive regions were identified. Further research provides evidence that the transient micro-latch-up event in the peripheral circuits based on complementary metal oxide semiconductor (CMOS) process is a main cause of the transient data upsets. Moreover, neutron irradiation is performed in order to mitigate the upsets caused by transient micro-latch-up. Due to the reduction of the current gains of the parasitic bipolar transistors by neutron-induced displacement damage, transient micro-latch-up as well as the resulting data upsets was suppressed.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
