方案下载应用领域 | 石油/化工 |
检测样本 | 无机盐 |
检测项目 | 可靠性能 |
参考标准 | 暂无 |
采用立陶宛EKSPLA公司NT342B-20-SH-SFG型纳秒波长可调谐光学参量振荡器(OPO)对镁离子水合物(Mg(H2O)n]+, n = 20–70)的电子光谱与纳米量热法进行了测量研究,讨论了是否会自发形成水合电子的问题。
Hydrated singly charged magnesium ions [Mg(H2O)n]+ are thought to consist of an Mg2+
ion and a hydrated electron for n > 15. This idea is based on mass spectra, which exhibit
a transition from [MgOH(H2O)n-1]+ to [Mg(H2O)n]+ around n = 15–22, black-body infrared
radiative dissociation, and quantum chemical calculations. Here, we present
photodissociation spectra of size–selected [Mg(H2O)n]+ in the range of n = 20–70
measured for photon energies of 1.0–5.0 eV. The spectra exhibit a broad absorption from
1.4 to 3.2 eV, with two local maxima around 1.7–1.8 eV and 2.1–2.5 eV, depending on
cluster size. The spectra shift slowly from n = 20 to n = 50, but no significant change is
observed for n = 50–70. Quantum chemical modeling of the spectra yields several
candidates for the observed absorptions, including five- and six-fold coordinated Mg2+ with
a hydrated electron in its immediate vicinity, as well as a solvent-separated Mg2+/e- pair. The photochemical behavior resembles the one of the hydrated electron, with barrierless
interconversion into the ground state following the excitation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
