用和频光谱(SFG)可视化观测运行中的OFET器件半导体/绝缘体界面处电荷活动状态
2019/03/07   下载量: 3
方案下载
应用领域 半导体
检测样本 其他
检测项目
参考标准 暂无
采用立陶宛Ekspla公司PL2230型脉冲皮秒激光器和PG501-DFG1P型皮秒光学参量发生器构成的和频光谱测量系统(SFG)对运行中的OFET器件半导体/绝缘体界面处电荷活动状态进行了可视化测量。
方案下载
配置单
方案详情
In our work, being aimed at clarifying the mechanism of charge transport in organic field-effect transistors (OFET) during operation and furthermore designing new OFET with higher performances, interfaces of OFET are studied by sum-frequency generation (SFG) spectroscopy. The effect of drain voltage on SFG spectra of OFET is obtained. A bias distribution of SFG intensities at 3000 cm-1 between source and drain electrodes caused by charge transport is obtained. Charge activities at the semiconductor/insulator interface of OFET during operation are preliminary mapped by SFG spectroscopy.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 时间分辨X射线散射法探测全长蓝藻植物色素的光诱导结构改变
文献贡献者
相关方案
当前位置: 欧兰科技 方案 用和频光谱(SFG)可视化观测运行中的OFET器件半导体/绝缘体界面处电荷活动状态
