方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | 可靠性能 |
参考标准 | 暂无 |
采用立陶宛Ekspla公司NT342B型纳秒(4ns)脉冲Nd:YAG可调谐激光器 输出的460nm激光对多种卤素吡啶样品进行了三阶非线性光学特性测量。研究了四种含芘查尔酮衍生物的合成。
Four chalcone derivatives 3a–3d based on pyrenyl donor and different halopyridyl acceptors were synthesized successfully. The resultant chromophores 3a–3d were characterized by nuclear magnetic resonance (NMR), high resolution mass spectra (HR-MS) and ultraviolet (UV) spectra. The theoretical calculations and thermal properties of the materials 3a–3d were systematically studied to illustrate structure-performance relationship. Further, a novel and unique method, 4f phase coherent imaging technology, was introduced to investigate the
third-order nonlinear optical properties of title compounds 3a–3d with 4 ns laser pulses at 460 nm. The thermal properties, the theoretical calculations and the experimental results consistently indicate that the compound 3b, namely 3-(5-bromopyridin-2-yl)-1-(pyren-1-yl) prop-2-en-1-one, is a more promising candidate for optoelectronic and nonlinear optical devices. Its third-order nonlinear absorption coefficient (β), refraction index (n2)
and polarization (χ(33)) are found to be up to such order of magnitude as 10−9 m/W, 10−16m2/W and 10−11 esu, respectively.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
