方案下载应用领域 | 石油/化工 |
检测样本 | 无机盐 |
检测项目 | 可靠性能 |
参考标准 | 暂无 |
采用立陶宛Ekspla研制的NT342B-SH型纳秒可调谐光学参量发生器输出的6 ns脉宽365nm波长的激光,激发Eu2+掺杂碱土金属氢化物氯化物AE7H12Cl2(Ae=Ca和Sr)样品,观察记录了其光致发光光谱。
In our study of the optical properties of Eu2+-doped alkaline-earth metal hydride chlorides AE7H12Cl2 (AE = Ca and Sr) we observe yellow (AE = Sr) and orange-red (AE = Ca) emission. Compared to the emission energies of Eu2+ - doped fluorides, chlorides and mixed fluoride chlorides, this corresponds to a wide redshift of the Eu2+ 4f65d1–4f7 emission. We explain this observation with the strong polarizability of the hydride anion and therefore
its strong nephelauxetic effect, which shifts the 5d barycenter to lower energy. Furthermore, the redshift is even significant compared to other known hydride chlorides and hydride oxide chlorides, which is probably caused by the relatively short AE2+/Eu2+−H− distances, or it might also be caused by impurity-trapped exciton states. We have also investigated the temperature dependence of the photoluminescence lifetimes and the thermal stability.
Even though the compounds are probably not ideal for phosphor application due to their low stability against air and moisture, our study underlines the large influence of the highly polarizable hydride anion on the optical properties of divalent europium and shows that Eu2+ could be used as a probe in mixed anionic system to determine the hydride content.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
