方案下载应用领域 | 航空航天 |
检测样本 | 航天 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司PDI-200型二维相位多普勒粒子干涉仪,对发动机燃料径向旋流混合器采用V型构型的空气动力学性能进行了实验研究。
The efficiency of modern Gas Turbine can be increased by accelerating the atomization
and evaporation of liquid fuel injected into the combustor. Chevrons mixers, seen in service on today’s advanced jet engines, generate streamwise vorticity off of the chevron tips which is able to quickly mix two separate flows and reduce the exhaust noise of these engines. The enhanced mixing ability of a chevron exhaust nozzle motivated the investigation of chevrons a typical combustion swirling flow, where fuel-air mixing is a limiting factor of the combustion system’s performance.
The focus of this research is to experimentally investigate the isothermal aerodynamic
and multi-phase flow properties of radial-radial counter rotating swirl cups with chevron mixing
generators. Each swirl cup assembly features a primary swirler with a converging-diverging
venturi, secondary swirler, exit flare with a 72° expansion angle, and a simplex fuel nozzle with a flow number of 0.7 and spray angle of 80°. Six unique trailing edge designs were applied to the primary swirler: four chevron designs, one shortened venturi, and one baseline. Confined and unconfined aerodynamic studies by 2D Laser Doppler Velocimetry was coupled with flow visualization and 2D Phase Doppler Interferometry to characterize the single and multi-phase flow properties of the different trailing edge designs.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
