方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium公司的相位多普勒粒子干涉仪PDI对喷雾对象的体积流量进行了测量。并尝试寻找优化参数设置。结果显示,在正确设置优化测量参数的前提下,PDI测量计算体积通量的结果和作为对比的机械图样测试的结果的符合度达到了非常高的98%。
Characterization of the volume flux distribution for a spray is a first order determinant for evaluating spray performance. The phase Doppler interferometer instrument has been well established as a means for accurately and reliably measuring drop size and velocity distributions in sprays. Utilizing these spray characteristics combined with local number density (concentration), the phase Doppler interferometer can provide a nonintrusive, in situ volume flux measurement. With the advancement of the phase Doppler Interferometry technique, the evaluation and comparison of instrumentation capable of measuring volumetric flux is an important step in validating these data for a wide range of industrial spray applications.
In the current study, experimental results of volume flux were acquired using Mechanical Patternation (MP) and Phase Doppler Interferometry (PDI) techniques. The baseline measurements in the present study were obtained using mechanical patternation of a hydraulic, low capacity, flat fan spray nozzle. Through controlled testing methods, the Artium PDI system, which incorporates the Artium AIMS auto setup software, was shown to very accurately determine the volume flux for the spray nozzle at multiple locations within the spray plume as well as D30 and velocity results. Additionally, the effect of receiver lens selection, slit aperture, and PMT gain were examined. Volume flux agreements as high as 98.8% were acquired between the MP point method and the PDI, when appropriate setup methods were implemented.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
