方案下载应用领域 | 地矿 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 无需 |
利用脉冲Nd:YAG激光器作光源,采用三台CMOS相机做成像器件,用组合的粒子图像PIV和跟踪测速PTV技术研究了砂砾动力学。
Accurately assessing the response of sediments to oscillatory flows requires high-resolution fluid velocity and sediment transport measurements at the fluid–sediment interface. Fluid and sediment grain velocities were measured simultaneously with combined particle image and tracking velocimetry under oscillatory flows over movable sand ripples. Three high-speed cameras equipped with varying optical filters were used to distinguish between fluorescent fluid tracers and the grains, from which the fluid and grain velocities were determined, respectively. Individual grains were tracked during transport to determine velocities and trajectories. Sediment grains were first mobilized by a vortex impacting the bed during flow reversal and suspended into the water column just prior to vortex ejection from the ripple crest, similar to previous observations. During phases of maximum flow velocity, additional grains were mobilized by the shear stress and were subsequently suspended. The flow reversed and similar observations were made in the opposite direction.Consequently, four peaks in suspended sediment concentration were observed throughout the flow cycle, consistent with previous observations. However, some previous researchers attributed peaks in suspended sediment concentration occurring during phases of maximum flow velocity to sediment-laden vortices that were shed from adjacent ripples. The measured sediment grain velocities were of similar magnitude and phase to the near-bed fluid velocities when the grains were being advected with the flow. Measurements of suspended sediment concentration agreed well with semiempirical formulations having an average root-mean-square deviation of approximately 4 3 1025m3m23. Predictions of settling velocity also
compared well with the laboratory estimates, agreeing to within 90%.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
