一种用于时间分辨层析PIV的高效准确的MTE-MART算法
2019/07/16   下载量: 1
方案下载
应用领域 航空航天
检测样本 航空
检测项目
参考标准 暂无
采用三台LaVision公司的ImagerProHS高速相机,加上DaVis7.4软件平台,对风洞中的翼型进行了时间分辨层析PIV测量,并用一种新型的高效准确的MTE-MART算法,对结果进了分析处理,并比较了这种算法与其它多种算法的性能。
方案下载
配置单
方案详情
The motion-tracking-enhanced MART (MTEMART;Novara et al. in Meas Sci Technol 21:035401,2010) has demonstrated the potential to increase the accuracy of tomographic PIV by the combined use of a short sequence of non-simultaneous recordings. A clear bottleneck
of the MTE-MART technique has been its computational cost. For large datasets comprising time-resolved sequences, MTE-MART becomes unaffordable and has been barely applied even for the analysis of densely seeded tomographic PIV datasets. A novel implementation is
proposed for tomographic PIV image sequences, which strongly reduces the computational burden of MTE-MART, possibly below that of regular MART. The method is a sequential algorithm that produces a time-marching estimation of the object intensity field based on an enhanced guess, which is built upon the object reconstructed at the previous time instant. As the method becomes effective after a number of snapshots (typically 5–10), the sequential
MTE-MART (SMTE) is most suited for time-resolved sequences. The computational cost reduction due to SMTE simply stems from the fewer MART iterations required for each time instant. Moreover, the method yields superior reconstruction quality and higher velocity field measurement precision when compared with both MART and MTE-MART. The working principle is assessed in terms of computational effort, reconstruction quality and velocity
field accuracy with both synthetic time-resolved tomographic images of a turbulent boundary layer and two experimental databases documented in the literature. The first is the time-resolved data of flow past an airfoil trailing edge used in the study of Novara and Scarano (Exp Fluids 52:1027–1041, 2012); the second is a swirling jet in a water flow. In both cases, the effective elimination of ghost particles is demonstrated in number and intensity within a short temporal transient of 5–10 frames, depending on the seeding density. The increased value of the velocity space–time correlation coefficient demonstrates the increased velocity
field accuracy of SMTE compared with MART.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 使用层析成像重建和三角测量的组合进行双帧粒子跟踪的三维测速方法
文献贡献者
相关方案
当前位置: 欧兰科技 方案 一种用于时间分辨层析PIV的高效准确的MTE-MART算法
