方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
利用LaVision的DaVis软件平台,加载抖盒子分析(STB)软件模块,考虑附加约束条件和多重网格近似,通过VIC+从粒子轨迹重构4D流场。
The present work investigates how to enhance Vortex-in-Cell-plus (VIC+) [1], capable of
reconstructing 4D flow field from dense time-resolved particle track measurement such as Shake-the-Box (STB,4D-PTV) [2, 3]. This study focuses on two aspects: removal of the necessity of initial condition and improvement of computation speed. For the former, the criteria of the parameters, for updating boundary condition and for weighting time derivatives, are modified to be evaluated from STB without an initial guess of the flow field. In addition, the continuity equation and Navier-Stokes equation from which additional constraints to flow field are derived are newly integrated into the cost function of VIC+ in order to update the
boundary condition progressively and reliably. For the computational speed, a concept of the iterative multigrid approximation [4] is adopted in order both to save the computational resource and to provide more desirable flow field by cropping out the erroneous computation boundary before triggering a successive VIC+ optimization for the finer grid scheme. STB measurement under the densely seeded condition is taken into account and its fluid structures, pressure field, and computational performances are demonstrated.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
