方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的 FlowMaster-3S相机和DaVis软件构成粒子成像测速系统,对具有不同气态烃燃料的钝体稳定2D,V形湍流预混火焰的动力学与吹脱特性进行了实验研究
‘Fire’ is unequivocally one of the greatest discoveries in human history. Anthropological
evidences say that the early ancestors of ‘Homo sapiens’ had a lot of interest in this particular
process of chemical reaction between aerial oxygen and fuel (essentially called fire) over
thousands of years for cooking food, keeping predators away and most importantly to stay warm during the coldest periods of years. In present days, the above-mentioned chemical reaction process popularly known as ‘combustion’ finds most of its application in power generation and propulsion applications. Of different kinds of combustion processes, extensive amount of research related to turbulent premixed combustion has been conducted so far because of its widespread application in propulsion and energy devices such as spark ignition engines, aviation and landbased gas turbines etc. All these devices include a flame during the process of combustion and hence, the study of flames is one of the most important aspects of combustion research. Flames are primarily divided in two different categories, popularly known as ‘laminar’ and ‘turbulent’ flames. However, for the requirement of compact size and efficient mixing, most practical combustors include turbulent flames. For any combustor, mixing and flame stabilization is extremely important from the point of view of design. Commonly used flame stabilization methods involve bluff body stabilization, swirl stabilization or combination of both. Bluff body flame stabilization is found generally in afterburner applications such as in military aircrafts and in a few jet engines to provide an increased amount of thrust.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
