方案下载应用领域 | 能源/新能源 |
检测样本 | 煤炭 |
检测项目 | |
参考标准 | 暂无 |
LaVision imager intense型CCD相机加上图像增强器IRO构成了一套OH自由基激光诱导荧光测量系统。利用这套系统对旋转稳定的贫预混合火焰燃烧动力学:火焰稳定化,火焰动力学和燃烧不稳定控制策略等进行了实验研究
Though modern low-emission combustion strategies have been successful in abating the emission of pollutants in aircraft engines and power generation gas turbines, combustion instability remains one of the foremost technical challenges in the development of next generation lean premixed combustor technology. Combustion instability is the coupling between unsteady heat release and combustor acoustic modes where one amplifies the other in a feedback loop. This is a complex phenomenon which involves unsteady chemical kinetic, fluid mechanic and acoustic processes that can lead to unstable behavior and could be detrimental in ways ranging from faster part fatigue to catastrophic system failure. Understanding and controlling the onset and propagation of combustion instability is therefore critical to the development of clean and efficient combustion systems. Imaging of combustion radicals has been a cornerstone diagnostic for the field of combustion for the past two decades which allows for visualization of flame structure and behavior. However, resolving both temporal and spatial structures from image-based experimental data can be very challenging. Thus, understanding flame dynamics remains a demanding task and the difficulties often lie in the chaotic and non-linear behavior of the system of interest. To this end, this work investigates the flame dynamics of lean premixed swirl stabilized flames in two distinct configurations using a variety of high fidelity optical and laser diagnostic techniques in conjunction with advanced data / algorithm based post-processing tools.
The first part of this work is focused on establishing the effectiveness of microwave plasma discharges in improving combustor flame dynamics through minimizing heat release and pressure fluctuations. The effect of continuous, volumetric, direct coupled, non-equilibrium, atmospheric microwave plasma discharge on a swirl stabilized, lean premixed methane˗air flame was investigated using quantitative OH planar laser induced fluorescence (PLIF), spectrally resolved emission and acoustic pressure measurements. Proper Orthogonal Decomposition (POD) was used to post-process OH-PLIF images to extract information on flame dynamics that are usually lost through classical statistical approaches. Results show that direct plasma coupling accelerates combustion chemistry due to the non-thermal effects of plasma that lead to significantly improved combustor dynamics. Overall, this study demonstrates that microwave direct plasma coupling can drastically enhance dynamic flame stability of swirl stabilized flames especially at very lean operating conditions.
The second part of this work is focused on the development of a stable and efficient small-scale combustor architecture with comparable power density, performance and emission characteristics to that of existing large-scale burners with reduced susceptibility to extinction and externally imposed acoustic perturbations while maintaining high combustion efficiency and low emission levels under ultra-lean operating conditions. Prototype burner arrays were additively manufactured, and the combustion characteristics of the mesoscale burner array were studied using several conventional and optical diagnostic techniques. The burner array was specifically configured to enhance overall combustion stability, particularly under lean operating conditions, by promoting flame to flame interactions between the neighboring elements. Dynamic mode decomposition (DMD) analysis based on high speed OH-PLIF images was carried out to provide a quantitative measure of flame stability. Results show a marked improvement in combustion stability for a mesoscale burner array compared to a single swirl-stabilized flame with similar power output. Overall, this study shows promise for integration of mesoscale combustor arrays as a flexible and scalable technology in next generation propulsion and power generation systems.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
