方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的图像增强器IRO,CCD相机,DaVis软件平台,搭建了一套干涉米氏成像和平面激光诱导荧光联合测量系统。研究了多分散喷雾中液滴分散和蒸发的相互作用过程。
The interaction between droplet dispersion and evaporation in an acetone spray evaporating under ambient conditions is experimentally studied with an aim to understand the physics behind the spatial correlation between the local vapour mass fraction and droplets. The influence of gas-phase turbulence and droplet–gas slip velocity of such correlations is examined, while the focus is on the consequence of droplet clustering on collective evaporation of droplet clouds. Simultaneous and planar measurements of droplet size, velocity and number density, and vapour mass fraction around the droplets, were obtained by combining the interferometric laser imaging for droplet sizing and planar laser induced fluorescence techniques (Sahu et al., Exp.Fluids, vol. 55, 1673, 2014b, pp. 1–21). Comparison with droplet measurements in a non-evaporating water spray under the same flow conditions showed that droplet evaporation leads to higher fluctuations of droplet number density and velocity relative to the respective mean values. While the mean droplet–gas slip velocity was found to be negligibly small, the vaporization Damköhler number (Dav) was
approximately ‘one’, which means the droplet evaporation time and the characteristic time scale of large eddies are of the same order. Thus, the influence of the convective effect on droplet evaporation is not expected to be significant in comparison to the instantaneous fluctuations of slip velocity, which refers to the direct effect of turbulence. An overall linearly increasing trend was observed in the scatter plot of the instantaneous values of droplet number density (N) and vapour mass fraction (YF). Accordingly, the correlation coefficient of fluctuations of vapour mass fraction and droplet number density (Rny) was relatively high (0:5) implying moderately high correlation. However, considerable spread of the N versus YF scatter plot along both coordinates demonstrated the influence on droplet evaporation due to turbulent droplet dispersion, which leads to droplet clustering. The presence of droplet clustering was confirmed by the measurement of spatial correlation coefficient of the fluctuations of droplet number density for different size classes (Rnn) and the radial distribution function (RDF) of the droplets. Also, the tendency of the droplets to form clusters was higher for the acetone spray than the water spray, indicating that droplet evaporation
promoted droplet grouping in the spray. The instantaneous group evaporation number
(G) was evaluated from the measured length scale of droplet clusters (by the RDF) and the average droplet size and spacing in instantaneous clusters. The mean value of G suggests an internal group evaporation mode of the droplet clouds near the spray centre, while single droplet evaporation prevails near the spray boundary. However, the large fluctuations in the magnitude of instantaneous values of G at all measurement locations implied temporal variations in the mode of droplet cloud evaporation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
