方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司由DaVis软件平台和ImagerPro型相机构成的粒子成像测速系统,对于水洞中的含有粗糙表面的流体的流场进行了测量并利用本征正交分解等数学工聚,对流动结构和水洞壁面表面粗糙度的相关性进行了实验研究。
High Reynolds number flow inside a channel of rectangular cross section is examined using Particle Image Velocimetry. One wall of the channel has been replaced with a surface of a roughness representative to that of real hydropower tunnels, i.e. a random terrain with roughness dimensions typically in the range of ≈10% - 20% of the channels hydraulic radius. The rest of the channel walls can be considered smooth. The rough surface was captured
from an existing blasted rock tunnel using high resolution laser scanning and scaled to 1:10. For quantification of the size of the largest flow structures, integral length scales are derived from the auto-correlation functions of the temporally averaged velocity. Additionally, Proper Orthogonal Decomposition (POD) and higher-order statistics are applied to the instantaneous snapshots of the velocity fluctuations. The results show a high spatial heterogeneity of the velocity and other flow characteristics in vicinity of the rough surface, putting outer similarity treatment into jeopardy. Roughness effects are not confined to the vicinity of the rough surface but can be seen in the outer flow throughout the channel, indicating a different behavior than postulated by Townsend’s similarity hypothesis. The effects on the flow structures vary depending on the shape and size of the roughness elements leading to a high
spatial dependence of the flow above the rough surface. Hence, any spatial averaging,
e.g. assuming a characteristic sand grain roughness factor, for determining local flow parameters becomes less applicable in this case.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
