方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | 老化性能>耐湿热性 |
参考标准 | 暂无 |
采用LaVisin公司DaVis软件平台为核心搭建了平面激光诱导荧光(PLIF), 粒子跟踪测速,以及红外测温平台。利用这一测量平台对降落液膜传热特性进行了实验和计算研究
An optical technique that combines planar laser-induced fluorescence (PLIF), particle tracking velocimetry (PTV) and infrared thermography (IR) was applied for the investigation of the hydrodynamic and heat transfer characteristics of harmonically-excited liquid films falling under the action of gravity over an inclined, electrically heated glass-substrate. PLIF was used to recover film-height data, PTV to recover two-dimensional (2D) velocity-field data, and IR to recover the temperature of the gas-liquid interface. The experiments were complemented by direct numerical simulations (DNSs) that provide additional information on the liquid viscosity, temperature and velocity distributions between the flow inlet and the downstream location where the optical measurements were collected. By adoption of this synergistic approach we recover a wealth of information, including novel results on the spatiotemporal evolution of the interface topology, and the flow and temperature fields underneath the wavy interface. Based on this data we also deduce local and instantaneous
heat transfer coefficients (HTCs), and focus our efforts towards the investigation of two HTC-enhancement mechanisms; the observation of “hot-spots” as precursors to the formation of thermal rivulets, which can result in local enhancements in excess of 50%, and the presence of large velocity components in the crossstream direction of the flow, which promote mixing and are shown to improve heat transfer by up to 7% compared to flow regions of the same height.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
