方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的突发式PLIF测量系统及双像器,对非定常火焰放热区进行了突发模式OH/CH2O平面激光诱导荧光成像测量研究。
The paper presents simultaneous high-speed (7.5 kHz) planar laser-induced
fluorescence (PLIF) of formaldehyde (CH2O) and the hydroxyl-radical (OH) for visualization
of the flame structure and heat release zone in a non-premixed unsteady CH4/O2/N2 flame.
For this purpose, a dye laser designed for high-speed operation is pumped by the secondharmonic
532 nm output of a Nd:YAG burst-mode laser to produce a tunable, 566 nm beam.
After frequency doubling a high-energy kHz-rate narrowband pulse train of approximately
2.2 mJ/pulse at 283 nm is used for excitation of the OH radical. Simultaneously, CH2O is
excited by the frequency-tripled output of the same Nd:YAG laser, providing a highfrequency
pulse train over 10 ms in duration at high pulse energies (>100 mJ/pulse). The
excitation energies enable signal-to-noise ratios (SNRs) of ~10 and ~60 for CH2O and OH
PLIF, respectively, using a single high-speed intensified CMOS camera equipped with an
image doubler. This allows sufficient SNR for investigation of the temporal evolution of the
primary heat release zone and the local flame structure at kHz rates from the spatial overlap
of the OH- and CH2O-PLIF signals.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
