方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的DaVis8.2软件平台和两台CCD相机,建立了一套双视角显微层析成像全息流场测量系统。
This paper introduces the application of microscopic dual-view tomographic holography
(M-DTH) to measure the 3D position and motion of micro-particles located in dense suspensions. Pairing of elongated traces of the same particle in the two inclined reconstructed fields requires precise matching of the entire sample volume that accounts for the inherent distortions in each view. It is achieved by an iterative volumetric self-calibration method, consisting of mapping one view onto the next, dividing the sample volume into slabs, and cross-correlating the two views. Testing of the procedures using synthetic particle fields with imposed distortion and realistic errors in particle locations shows that the self-calibration method achieves a 3D uncertainty of about 1um, a third of the particle diameter. Multiplying the corrected intensity fields is used for truncating the elongated traces, whose centers are located within 1um of the exact value. Without correction, only a small fraction of the traces even overlap. The distortion correction also increases the number of intersecting traces in experimental data along with their intensity. Application of this method for 3D velocity measurements is based on the centroids of the truncated/shortened particle traces. Matching of these traces in successive fields is guided by several criteria, including results of volumetric cross-correlation of the multiplied intensity fields. The resulting 3D velocity distribution is substantially more divergence-free, i.e., satisfies conservation of mass, compared to analysis performed using single-view data. Sample application of the new method shows the 3D flow structure around a pair of cubic roughness elements embedded in the inner part of a high Reynolds number turbulent boundary layer.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
