方案下载应用领域 | 航空航天 |
检测样本 | 航天 |
检测项目 | |
参考标准 | 暂无 |
采用德国LaVision的Imager Pro X4M CCD相机和蔡司ZEISS 50mm f/2 Makro 镜头,测量了亚音速高马赫数跨音速涡轮叶栅尾流的2D2C速度矢量场并和五孔探针的测量结果进行了对比分析。
Five-hole-probes are common use in turbomachinery flow investigations, even though, inserting a probe into a flow field inevitably induces perturbations to the flow which can falsify
the measurement results, especially when exposed to transonic flows. The objective of the investigations presented here is to evaluate the Mach number measurements of a five-hole-probe (5HP) in the wake flow of a transonic turbine cascade at engine relevant Reynolds numbers by comparing them to the results of particle image velocimetry (PIV). Furthermore, PIV measurements were performed with inserted probe to investigate the influence of the probe on the wake flow field. Together with a sensitivity study of 5HP measurements in flow regimes close to Ma=1, the results demonstrate how the measurement uncertainty can be improved in high subsonic flow regimes.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
