方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的同轴体视速度测量系统-机器人式体视PIV对风洞中的球体和假人的流场进行了测量,并通过流场数据获得了表面压力的可视化信息。
Some recent trends in the development of PIV techniques are leading to the realization of
velocity measurement at large scale. Moreover, methods for evaluating the fluid flow pressure from PIV data have been successfully demonstrated at small scale and for simple geometries. Methods for quantitative visualization of surface flow properties such as skin-friction and pressure are comparatively less developed, despite the great interest for the aerodynamic insight they provide for the study of the flow around 3D complex objects.
The accuracy of the pressure evaluation at the surface is inquired in this work by dedicated measurements over a sphere at Red = 8 × 104. The measurements made with robotic PIV are compared to direct surface pressure measurements. The solution of the Reynolds averaged momentum equations is performed with the Poisson problem formulation and the results are compared with potential flow theory and some simplified models. The accuracy of stagnation pressure depends upon the measurement resolution. Instead, the suction
peak region is generally underestimated. The pressure in the separated region is retrieved with sufficient accuracy.
The surface flow properties visualization of a time-trialing full-scale cyclist replica at 14 m/s (Re = 5.5×105) is performed as a demonstration of the above method to a complex 3D problem at large scale. The data obtained with the robotic PIV technique is analyzed in close proximity of the solid surface and the skin friction lines of the time averaged velocity field are inspected. The topological analysis of the skin friction lines yields clearly the evolution of the flow around the body segments returning the details of the separated flow regions and local recirculation zones. The analysis of the surface pressure distribution yields results in
accordance with the skin-friction lines, the outer flow velocity field as well as the vortex topology.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
