方案下载应用领域 | 医疗/卫生 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision的图像采集和处理软件平台以及LDY300型双脉冲PIV激光器,ImagerProSX 5M 型双帧双爆光相机,构成一套粒子成像测速系统(PIV) ,并利用该系统对轴流式血泵在三种工况下流场特性进行了实验研究
In order to investigate the internal flow field of an axial blood pump, two-dimensional (2D) particle image velocimetry (PIV) was applied to test the blood pump under three different conditions. Acquiring the images of inlet, front guide vane, impeller, back guide vane and outlet area, the distribution of internal flow field was then analysed. The rotation speed of the
blood pump was set to 6000, 7000 and 8000 r/min, respectively. The results show that the flow field of blood pump is stable relatively at the inlet area. Some vortices and reflux existed due to the block of guide vane in the import and impeller area. With the increase of rotating speed, the overall disturbance degree of flow field increases. Under the condition of low rotation speed, the flow field acceleration is insufficient. Under the medium rotation speed condition, the flow field is stable and the velocity distribution is even. Under the condition of high rotating speed, the number of vortices in the flow field increased significantly, the flow separation phenomenon at the impeller was obvious and more unstable flow appeared at the back guide vanes and outlet area.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
