克服幼年砂眼蛤蜊悬浮喂养时的水动力学挑战
2019/08/14   下载量: 0
方案下载
应用领域 生物产业
检测样本 其他
检测项目
参考标准 暂无
采用LaVision公司的DaVis软件,FASTCAM SA3 120K 单色高速相机(Photron,Tokyo, Japan),1WLED光源,构成一套显微粒子成像测速系统。测量了砂眼蛤蜊悬浮喂养时4mmX4mm视场区域的流动速度矢量场分布。
方案下载
配置单
方案详情
    We present some of the few suspension-feeding measurements and to our knowledge the first velocity-field measurements for early post-settlement juvenile bivalve clams. We verify and extend our experimental results with numerical simulations. For 1.8–2.8mm shell length Mya arenaria clams, pumping rates ranged 0.03–0.22 ul/s, inhalant siphon Reynolds numbers (Re) ranged 0.16–0.79 and mean inhalant velocities ranged 0.8–3.2mm/s. Owing to the low Re at which they pump and the small diameters of their siphons, juvenile clams are subject to unique hydrodynamic challenges, including high siphon resistance and susceptibility to refiltration. At least three features of juvenile clam siphons differentiate them from those of
adults–shorter inhalant siphon length, a more rapid increase in inhalant siphon diameter with shell length, and the presence of a prominent exhalant siphon extension. These features are probably adaptations to the challenges of suspension feeding at low Re.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 评估纳米流体在湍流自然对流过程中的流动特性
文献贡献者
相关方案
当前位置: 欧兰科技 方案 克服幼年砂眼蛤蜊悬浮喂养时的水动力学挑战
