用于低速非常规蒸汽流的粒子图像测速的可行性
2019/08/14   下载量: 1
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
采用LaVision的Davis 8.3.0软件平台,IagerHS4M高速相机,以及LDY300高重频激光器,构成一套时间分辨粒子成像测速系统(TR-PIV),并利用该系统对低速非常规蒸汽流流场进行了实验测量和理论分析。
方案下载
配置单
方案详情
    This work assesses the feasibility of the planar PIV technique to study the characteristics of a siloxane vapor D4. Titanium dioxide (TiO2) seeding particles were used to track the motion around a rotating disk in a low speed flow. Vector fields of natural convection (NC) and a superposition of NC and rotating flow were selected as exemplary cases. The particles were capable of tracing the flow since the calculated Stokes number St is 6.5 × 10^-5. The quality of the experimental data is assessed by means of particle seeding density and particle
image Signal to Noise ratio (S/N). The final results are deemed acceptable for an accurate assessment of the flow field. Rejected outliers are below 2.3% and the relative uncertainties corresponding to the average velocity fields are below 1%.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 使用荧光PIV表征喷雾诱导的湍流
文献贡献者
相关方案
当前位置: 欧兰科技 方案 用于低速非常规蒸汽流的粒子图像测速的可行性
