方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用美国Artium 公司的PDI-200MD型相位多普勒粒子干涉仪,测量了水喷雾中的液滴粒径和速度等参数。研究了水喷雾对多“细胞”结构常规爆轰的影响。
Detonation propagation in heterogeneous media has been an old topic interesting researchers for both propulsion improvements and hazards prevention ([1], [2]). In this large context, a more specific topic has been investigated by Thomas et al. ([3], [4]) where they highlighted conditions to mitigate detonations and deflagrations propagating in hydrocarbon-air atmospheres with water spray having large droplets (greater than 100 um). These studies revealed the strong influence of small droplets (lower than 30 um) in quenching a detonation and a deflagration, and defined that a detonation quenching is obtained with velocity deficits up to 10 % of the theoretical detonation velocity in a dry atmosphere.
Furthermore, recent numerical ([5]) and experimental works ([6], [7]) confirmed the role of fine sprays in dampening a detonation. In [7] the authors also showed the strong influence of a spray with 10 um droplets in enlarging cellular structures and thus slowing down the kinetic processes, without significantly impacting the detonation velocity propagation and the pressure profiles observed downstream of the detonation front.
To follow the previous works, this paper presents preliminary results dealing with a detonation propagation in C2H4+3O2+ZAr, for an equivalence ratio ranging from 0.8 to 1.1, with an argon dilution Z = 28 which refers to a 90 % dilution in mass, with a fine water spray reaching an apparent density of approximately 130 g=m^3. Pressure results, detonation velocities, cellular structures have been recorded and are analyzed, along with a spray characterization. As the previous study [7] describes the experimental apparatus involved in these experiments and gathers results of ethylene-air detonation diluted with the same water
spray (approximately same mass fraction, arithmetic and Sauter mean diameter), only a brief description of the set-up is recalled. The numerous experimental results will then be compared with this work: detonation velocity analysis, cellular structure and pressure analysis. Conclusions are drawn afterwards.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
