方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用德国LaVision公司的SprayMaster喷雾测量分析系统和美国Artium Technologies 公司的相位多普勒粒子分析仪PDI-200MD对喷雾的几何形态和液滴的粒径速度进行了测量获得了组合液滴尺寸分布信息。
In this investigation, methods used to generate combined drop size distributions, from discrete measurement points, are developed and evaluated. A hydraulic, at spray and an internally air-atomized, multi-orifice spray are investigated experimentally; representing common but distinctly difierent sprays. The details of each spray plume are captured with an extensive matrix of measurement points, which are then used to evaluate the drop size distribution difierence across each spray plume, and to calculate combined drop size
distributions throughout a planar cross-section of each spray. Weighted-average distributions are generated, using the local flux and discrete area at each measurement point, which are relevant physical characteristics within each spray plume. It was found previously by Bade and Schick [1] that measurements should be performed at approximately each 10% interval of the overall spray plume size in order to achieve errors less than 5% for combined spray plume statistics. Also, the measurements should be performed along both the x and y axis for a flat spray, and along a single-axis from the center-to-edge for a multi-orifice air-atomized spray for drop size investigations. The developed methods allow the logical combination of
drop size distributions, collected at many points, to be used to generate holistic drop size distributions that are representative of a planar cross-section within a spray plume.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
