离子表面活性剂体系的表面流变学研究,重点关注振荡气泡技术
2019/12/03   下载量: 1
方案下载
应用领域 石油/化工
检测样本 其他
检测项目 理化分析
参考标准 暂无
采用立陶宛EKSPLA公司由PL2143A/SS型固体锁模皮秒脉冲激光器和PG 401/DFG2-10P型皮秒光学参量发生器为核心构成的和频光谱测量系统,对离子表面活性剂体系进行了表面流变学研究,重点关注振荡气泡技术。
方案下载
配置单
方案详情
Surface active agents, shortly referred to as surfactants, tune the air-water interface with respect to both its equilibrium and dynamic properties. On a macroscopic scale, the formation of foam is the most prominent characteristic of a surfactant solution. It takes place when subjecting an aqueous solution to mechanical deformation.
Prime motivation of the research presented in this thesis is to obtain a better understanding of
air-water interfaces on a molecular scale and to relate this knowledge to colloidal systems which are naturally determined by an unusual ratio of surface to volume. In particular, this thesis aims for an understanding of the relationship between the microscopic structure of an adsorption layer and the molecular structure of its constituent molecules. Moreover, relating the microscopic properties of an interface to the macroscopic behavior of a system is a major objective.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 基于速度测量误差的加权最小二乘法4D流场MRI压力估计
文献贡献者
相关方案
当前位置: 欧兰科技 方案 离子表面活性剂体系的表面流变学研究,重点关注振荡气泡技术
