方案下载应用领域 | 能源/新能源 |
检测样本 | 天然气/燃气 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的SprayMaster喷雾米氏散射成像测量和Artium公司的相位多普勒粒子干涉仪PDI对燃气轮机模型燃烧室液体单组分燃料贫爆的差异进行了测量和研究。
The influence of selected single-component hydrocarbons on lean blowout behaviour of swirl-stabilised spray flames was investigated. Additional information on the spray characteristics was collected by Phase Doppler Anemometry (PDA) and Mie scattering measurements. The measurements were accomplished in a gas turbine model combustor under atmospheric pressure and at two different air preheat temperatures. The combustor featured a dual-swirl geometry and a prefilming airblast atomiser. The combustion chamber provided good optical access and yielded well-defined boundary conditions. Three single-component hydrocarbons were chosen: one short and one long linear alkane (n-hexane and n-dodecane) and one branched alkane (iso-octane). Kerosene Jet A-1 was used as a technical reference. Results show noticeable differences in the lean blowout limits of the various fuels, at comparable flow conditions. By using the results of the measurements, of additional modelling and of an assessment of the fuel properties it was concluded that fuel differences in lean blowout in this combustor can be due to differences in the physical properties as well as in the chemical properties.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
