方案下载应用领域 | 石油/化工 |
检测样本 | 柴油 |
检测项目 | 理化分析 |
参考标准 | 暂无 |
采用LaVision的激光诱导荧光和激光诱导白炽光测量方法,对生物柴油碳链长度对小口径光学柴油机缸内碳烟形成过程的影响进行了研究。
This study examines the effects of biodiesel carbon chain length on the development of high-temperature flame and soot in single-cylinder, light-duty, optical diesel engine. Planar laser-induced fluorescence of OH (OH-PLIF) and laser-induced incandescence (soot-PLII) are performed separately using petroleum diesel and two biodiesel surrogate fuels. The selected surrogate fuels have a saponification number (SN) of 330 and 233 for shorter and longer carbon chain length, respectively, while the iodine value (IV) characterising the degree of unsaturation is kept similar. The laser-based images are shown together with the chemiluminescence images of naturally occurring cool-flame signals and electronically excited OH (OH∗). The start of high-temperature reaction timing was matched for the tested fuels by adjusting the injection timing so that the in-cylinder ambient conditions at the start of combustion were consistent. The results show that the longer carbon chain biodiesel has shorter ignition delay time, which makes a significant impact on the spatial and temporal development of high-temperature reaction zones. The OH signals for the longer carbon chain length biodiesel are observed close to the piston-bowl wall whereas they appear later in the penetrating front of the wall-interacting jet for the shorter carbon chain length biodiesel. Both fuels show soot formation occurring in the wall-jet head region while the longer carbon chain length biodiesel has higher soot concentration and larger area than that of the shorter carbon chain biodiesel. This is due to lower pre-combustion mixing, reduced fuel oxygen content, and possibly less significant OH-induced soot oxidation.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
