方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The ASBN-DW-MINI is a miniature UV-Vis light source a continuous spectrum covering the whole range from deep UV to near Infrared ( spectrum curve ). This light source was developed in response to customer requests for a small UV-Light source with negligible heat generation. The features of this light source open the way for new solutions in small spectroscopy equipment and UV optics. Features are small size low power consumption (6 W) low heat generation easy coupling to optical fibers, measuring cells and capillaries lifetime up to 3 years robust mode of operation. The ASBN-DW-MINI incorporates a miniature Deuterium Lamp an electrode-less high frequency excited gas discharge lamp. The Deuterium Lamp features small size, 3Watt power consumption, and negligible heat generation. It is a complete UV-Vis light source with a shine-through design deuterium lamp, a 0.25 Watt tungsten lamp, shutter, optical system and SMA 905 connector or collimating output les set. All elements are mounted on a printed circuit board driven by an external 12 Vdc/600 mA power supply. Both lamps and the shutter can be controlled by a TTL signal. Feature Value Lamp: 3W Deuterium, 185-400nm 0.25W Tungsten-halogen, 400-1100nm Power: Approx. 6W. 12Vdc/0.6Adc Relative Humidity: Max. 90%, non-condensing Ambient Temperature: 5 - 35° C Shutter: Lamp off/dark current measurement, TTL controlled Functions: Deuterium and tungsten-halogen lamp can be triggered separately by a TTL signal Bulb Lifetime: Deuterium: >1,000 hours (50% intensity loss) Tungsten: >2,000 hours Connector: SMA 905 Fiber connector or collimated output 上海瞬渺与美国Spectral Products签定代理协议,成为其在中国区域的指定代理商 2010.11.21月在友好协商的气氛下,上海瞬渺光电于近期和美国Spectral Products公司正式签订代理协议,成为其在中国区域的指定代理商。上海瞬渺主要负责美国Spectral Products如下产品的本土销售和技术支持工作: 分光光度计、单色仪、光谱仪、摄谱仪、光谱分析仪、探测系统、光源 美国SP公司是世界光电技术仪器及产品的领导者,作为CVI的子公司,其光谱产品的研发有着非常丰富的经验及创新理念。产品范围覆盖:分光光度计、单色仪、光谱仪、摄谱仪、光谱分析仪、探测系统、光源
德国Qioptiq半导体激光器助力生命科学仪器研究
数字全息显微镜DHM检测分析MEMS陀螺仪谐振频率
量子通信波段论文及资料
红外连续可调OPO激光器 德国 Qioptiq
Phasics波前探测器SID4
FROG超短脉冲测量仪+自相关仪+Swamp optics+8-20-USB
Energetiq 激光驱动白光光源LDLS EQ-99XFC
红外相机
Onefive Katana 通用型脉冲激光器
Onefive Origami 低噪声孤子飞秒光纤激光器
美国electrophysics公司 红外相机 7290A
Lyncee 数字全息显微镜 DHM R2100
electrophysics 红外热像仪 ATOM80
OKO N50mm 37/79/109通道压电变形镜(PDM)
Beam Analyzer光束质量分析仪
中红外光谱仪
光纤激光器
光纤放大器
