方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
研究领域:微生物燃料电池MFC 交流阻抗频率范围:100kHz - 5mHz To understand the effects of acclimation schemes on the formation of anode biofilms, different electrical performances are characterized in this study, with the roles of suspended and attached bacteria in single-chamber microbial fuel cells (MFCs). The results show that the generation of current in single-chamber MFCs is significantly affected by the development of a biofilm matrix on the anode surface containing abundant immobilized microorganisms. The long-term operation with suspended microorganisms was demonstrated to form a dense biofilm matrix that was able to reduce the activation loss in MFCs. Also, a Pt-coated anode was not favorable for the initial or long-term bacterial attachment due to its high hydrophobicity (contact angle = 124°), which promotes easy detachment of the biofilm from the anode surface.
