方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
见附件 13691497252 侯先生 Decachlorobiphenyl elutes off of the “XLB” phase in 11.5 minutes, while the target compounds listed in EPA Method 8080 are 80% resolved on both columns. Optimization of the expanded list of compounds found in EPA Method 8081A resulted in 80% resolution of the 32 target compounds (plus the surrogates) on the Rtx-440, with the exception of kepone and endrin aldehyde. The Rtx-XLB phase under the same conditions has two poorly resolved pairs: endrin/2,4’-DDT & endosulfan II & kepone. The clear advantage of this column pair is the rapid analysis and low bleed without a sacrifice in resolution. These columns have the same elution order for the EPA 8080 pesticides, which is a disadvantage of this application. Although there are elution order differences for the expanded list and the retention times are different for all of the chlorinated pesticides there is still a need to find a more dissimilar stationary phase as a confirmation column
8分钟轻松完成EPA常规邻苯二甲酸酯检测
麻醉品中毒品成分的定性分析应用文献
毛细管气相色谱法测定盐酸金刚乙胺片的溶出度的应用文献
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
