厂家直销电热工业烘箱400-880-6667 质量上乘
DZF系列真空烘箱(DZFSeriesVacuum Drying Oven)
一、用途概述:
真空烘箱广泛应用与生物化学、化工制药、医疗卫生、农业科研、环境保护等研究应用领域,作粉末干燥、烘培以及各类玻璃容器的消毒和灭菌之用。特别适合于对干燥热敏性、易分解、易氧化物质和复杂成分物品进行快速高效的干燥处理。`
二、产品特点:
1、长方体工作室采用优质钢板或不锈钢板。钢化、防弹双层玻璃门观察工作室内物体一目了然。
2、箱门闭合松紧能调节,整体成型的硅橡胶门封圈,确保箱内高真空度。
3、微电脑智能控温仪,具有设定,测定温度双数字显示和PID自整定功能,控温精确,可靠。
4、加热功率比例可任意调节,确保低端控温无温度之弊。
一、Summary
Vacuum oven is widely applicable for drying and sterilization in fields of biochemistry, pharmacy, medicine and health, agriculture and scientific research and environment protection. It is designed specially for drying of material which is thermo-sensitive or decompounded and oxidative easily.
二、Features
1、The working chamber is ,made of high quality sheet or corrosion-resistant stainless steel.Toughened hulletproof double glass door,to observe clearly the object in the working chamber.
2、The air-tightness of the chamber door is adjustable,with a wholly shaped silicon rubber door sealing loop;so as to guarantee in-chamber high vacuum.
3、Intelligent temperature controller is based microprocessor with PID parameters controlling function.Digital display of set and actual temperatures.High temperature controlling accuracy and reliability.
4、Be sure to the temperature is not excess.and the heat up power can be adjusted.
三.技术参数。(Specifications):
型号Model |
DZF-6020 |
DZF-6030 |
DZF-6050 |
DZF-6090 |
DZF-6210 |
DZF-6250 |
电源电压Supply voltage |
220V ,50Hz |
380V ,50Hz |
控温范围Temperature range |
RT+10℃~250℃ |
温度波动Temperature fluctuation |
±0.5℃ |
消耗功率Consumption Power |
500W |
800W |
1400W |
2400W |
3600W |
4000W |
真空度Vacuum degree |
<133pa |
工作室尺寸
Interior Dimension(mm) |
300×300×275 |
320×320×300 |
415×345×370 |
450×450×450 |
560×590×640 |
700×600×600 |
外形尺寸
OverallDimension(mm) |
580×450×450 |
630×510×460 |
720×525×535 |
615×590×1470 |
720×820×1750 |
1050×760×910 |
搁板Chamber |
1 |
1 |
2 |
2 |
3 |
3 |
特别提示:凡需充惰性气体保护或对温度和真空度有特殊要求的用户请与制造商联系,定能满足您的要求。
除6090,6210和BPZ系列配真空泵外,其余型号均选配真空泵。
真空烘箱选配件:Vacuum drying oven accessories
程序液晶温度控制器 programmable LCD temperature controller 1000元
惰性气体进气阀 Inert gas valve 500元
下箱体柜 Under cabinet counter 1000元
液态水过滤器(适用高湿干燥用) Water filters 500元
真空泵Vacuum pump 2XZ-2 1300元 2XZ-4 1600元
真空度自动控制 Automatic vacuum
4500元
真空烘箱采用模拟工程学的数字技术控制真空度,“手动控制"早已成为历史。您还认为在21世纪的手动杠杆操作的阀门可以精确控制真空度吗?通过电磁阀全自动数显控制的真空度,为您提供更加精确有效的真空度控制。通过面板,真空度从0Pa至105Pa可调,可调精度为1Pa。传感器采用电阻硅管压力传感器,从而保证了稳定的压力值,不受气流的影响,把稳定的压力值传给真空控制仪LED显示屏上。配合相应大功率的真空泵,真空箱内真空度可以达到10Pa以下军工级别。
如果有兴趣还可以参观的我们的官网:http://www.hasuc.cn
http://www.hasuc.net
