方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In the present paper the fluid-structure-acoustic interaction of a thin flexible structure in the wake of a wall-mounted square cylinder is investigated experimentally. The experiments are performed in an acoustics wind tunnel employing microphone measurements of the sound pressure level. Detailed flow measurements are carried out using laser-Doppler anemometry and 3D-hot-wire anemometry. The flow induced vibration of the flexible structure is measured with a laser scanning vibrometer. Experimental results characterizing the flow field, the structural vibration and the generated sound are presented.
如何保护好你的CCD相机——PIV必读
水生生物触须后的流场研究
围绕窄圆柱的低雷诺数流体的三维影响
