方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Stereo-μPIV measurements have been performed to investigate the wake behind a vibrissa (facial hair) from a seal. Previous experiments have proven the capability of seals to detect the wake swimming fish by using only their vibrissae as a sensory system. Also it can be observed that the vibrissae of seals exhibit a unique 3D shaped structure. The aim of the present investigation is, to learn the fluid mechanic aspects of the wake detection and to understand the influence of the 3D surface structure on the detection capabilities. The measurements have made extensive use of a Stereo-μPIV device,which allows the capturing of the full un-steady 3D vector field on a set of 2D planes with microscopic length scales.
如何保护好你的CCD相机——PIV必读
围绕窄圆柱的低雷诺数流体的三维影响
气流中测量局部构成的二维激光诱导等离子谱的应用
