方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
An experimental and numerical study is carried out to investigate three-dimensional effects in the flow of Newtonian fluids around confined cylinders, for Reynolds numbers below 40 and aspect ratios between 1 and 16. Experiments rely on flow visualizations and detailed velocity measurements by PIV,while predictions were carried out using a finite volume method.
如何保护好你的CCD相机——PIV必读
水生生物触须后的流场研究
气流中测量局部构成的二维激光诱导等离子谱的应用
